1Longbow's avatar
1Longbow
Small Grey Tank drain pipe
We have a 2014 Wind River TT ,with 2 drains for the black and the grey tank. The grey tank pipe is very small diameter compared to the black tank,for obvious reasons,but the grey tank takes for ever to drain. Is there a reason for making the grey tank drain smaller? I don't seem to recall that on other TT that we have owned. Thank you
  • Is there a reason for making the grey tank drain smaller?
    Money.
  • Bobbo's avatar
    Bobbo
    Explorer III
    "Slow draining" is also subjective. The tank may be draining perfectly fine, but after watching the fluids drain from the black tank in the 3" line, the gray tank with its 1.5" line seems much slower.
  • slow draining is not likely caused by pipe size. You MAY have a clogged roof vent causing the slow draining.
  • it's not that the grey is so small it's that the black is large.
    1 1/2" drain pipe is common for 'water'
    3" is common for 'solids'
    Pretty much the same set up in a house drain system.
    Slow draining of your grey tank.......check for obstruction in grey tank vent line.
  • Smaller gray tank piping on both our previous 5'er and current MH...
  • I see this commonly on TTs and fivers, where the drain runs are long.
    Reason? Lower cost of materials?
  • It seems to be industry practice to use 3" for the black tank and 1-1/2" for the gray.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
