daytona7's avatar
daytona7
Smelly water after 3 days
Got a problem with my water. If I make a gallon of Ice Tea or anything else, after 3 days the water feels slimy and stinks if rinsing out with hot water. Even a rung out dish wash cloth starts getting raunchy smelling after 3 days. What would cause this problem?
  • I assume you are talking about water from your onboard tank. Bacteria growth can cause the problem. Did you fill your tank from a chlorinated water supply or from a well?
    Suggest you dump water, sanitize tank and make sure that when you refill you put some chlorine in the tank.
  • Are you using the on board tank? If so you need to sanitize...
    If you are in a park and seasonal you need to make sure the campground is not on a well..
    If a well you needs to sanitize often...
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Nov 28, 2025
