fitznj
May 08, 2017Explorer
I have a similar setup on my TT; I chose to install a charge controller next to the batteries and connect the solar array to this charge controller thus by-passing this 10A Receptacle;
WHy? If you use a battery disconnect switch (which I do when storing the TT); then you can't use the 10A Receptacle to charge your batteries. Also if you do not disconnect your batteries - then you may run down the battery if you have multiple cloudy days.
Also I have 320W of solar, which is more than 10A - my charge controller can handle more than 10A;
Looking for advice before your next adventure? Look no further.25,112 PostsLatest Activity: Feb 21, 2025
