I installed a solar panel this summer.Normally when I put the trailer in winter storage I usually remove the battery. So with a solar, panel installed with controller should remove the battery from...
Well if you live in a area that has more than 3" of snow on the ground most of the time (you do) and the panels will be covered with snow, they will not get to much power each day. Also your daily sun hours are reduced, and the angle is very low so you basically will not get much solar each day.
So I would remove the battery.
Fred.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 21, 2026
