KFT's avatar
KFT
Solar Panel Output Voltage
Hello.
I have just installed a 165W solar panel on my roof of my RV. I just took a voltage measurement of 40VDC from the leads coming off the panel. I bought this as a kit for my RV. I am confused to as why the voltage is so high. I guess the charge controller takes care of the voltage regulation output to the battery?
  • 40v open circuit could be completely normal for a large 72 cell solar panel. It's unlikely your 165 watt panel should be that high. If it's a 60 cell panel the Voc would probably be around 37, maybe higher if it's really cold outside.
    The charge controller will take care of the voltage regulation. I really hope the kit came with an MPPT controller. Otherwise, with that high a voltage you'll be wasting a lot of power when you hook it to a 12v battery.
  • What is the brand of solar panel that you measured?
  • yes. the charge controller takes care of the voltage control to the batteries
    FYI OCV 'open circuit voltage' nothing connected to the panels is always higher than loaded working voltage, which is higher than the 14v that goes to the controller
    always connect the controller to the batteries first
    then connect the solar panel to the batteries
    doing it the other way can burn out the controller
    it always says this in the controller instructions
    but people get in a hurry and do it backwards
    solar panel is the LAST item to be connected
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 16, 2026
