othertonka
Apr 27, 2014Explorer
From the roof, down the Refer vent and you take off the refer vent cover on the side of the RV and then you can find a existing hole or drill one to run the wire into the RV where1ver you need it to end up, n1ear the charge controller or house battery. It is easier if you remove the 4 screws on the roof that holds the refer vent in place. That way you have a visual to guide the wire down, staying away from the exhaust stack. Be sure that you have some dicor caulking to cover the screws when you reinstall the screws.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
