CA_Traveler
Jan 08, 2017Explorer III
WackAway wrote:Sure install a Magnum MSH3012M and it will combine battery power and gen power and it only cost $2,000. :S
Quick question. Is there a way to configure a system so I can combine the inverter output with the generator output to be able to run heavier loads like my AC units?
But wait A/Cs can draw 15A AC or 150A DC so you will need more batteries and more solar. Or a larger gen in which case you won't need the above hybird unit. On install a much smaller window A/C. :h
Lots of pricey options when you want to run high draw items off grid. :@
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
