Canadian_Rainbi
Jan 09, 2017Explorer
2oldman wrote:
You should assess your electrical needs first. That comes with a 3kw inverter. You really need that big an inverter? Do you have enough batteries to dry camp? How much dry camping do you do? Etc.
X2 And as was also said a KIT is usually more expensive than discrete components esp. since you will get what you want/need. Fewer panels, larger battery capacity or larger panels and less battery, large or small inverter etc etc etc.
Note though, if you are like many of us you will eventually wish you had more! Go for larger wire so if (when) you want to add a panel or two the leads will already be in place.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
