John___Angela
Jan 10, 2017Explorer
StirCrazy wrote:rjxj wrote:
that means that when your 480 watts is performing at its best in full sun TILTED it will only hit the batteries with 10 amps or so and maybe 15 plus at times.
that's way out. in September up north in the deep tundra (haha) with only two of there panels I was pulling 14 amps, he has three so they are rated up to 26 amps in his configuration and he should get very close to that considering he is down south. the panels used by go power are very high quality panels, not the cheep ones.
Agreed. With those conditions you will see in excess of 20 amps and probably close to 24 or 25. Its always the cosine off the incident angle and you can pretty much calibrate your meter with that. It is that accurate on a clear day.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
