azrving
Jan 10, 2017Explorer
John & Angela wrote:StirCrazy wrote:jrjxj wrote:
that means that when your 480 watts is performing at its best in full sun TILTED it will only hit the batteries with 10 amps or so and maybe 15 plus at times.
that's way out. in September up north in the deep tundra (haha) with only two of there panels I was pulling 14 amps, he has three so they are rated up to 26 amps in his configuration and he should get very close to that considering he is down south. the panels used by go power are very high quality panels, not the cheep ones.
Agreed. With those conditions you will see in excess of 20 amps and probably close to 24 or 25. Its always the cosine off the incident angle and you can pretty much calibrate your meter with that. It is that accurate on a clear day.
To be accurate you need to quote the whole thing. I said that when his panels are putting out full power and house load is considered, he may only hit the batteries with 10 to 15 amps.
"I went back and read your last post again. If you are pulling 1 to 5 amps with 4 or 5 things during the day just say it averages 15 amps that means that when your 480 watts is performing at its best in full sun TILTED it will only hit the batteries with 10 amps or so and maybe 15 plus at times. Not good. Normally we are not using a lot of power while the sun is cranking the power in. When the sun is gone we then draw the most power. For us the only big draw when the sun is out is our resi frig at 5.x amps at half the time. As it cools in the evening and sun is gone the furnace kicks on and the television is on plus the fridge.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
