rvartie's avatar
rvartie
Somehow got sediment in the fresh water tank
Out of the kitchen faucit, the water contains little black and clear specks. They are tiny but visible in the light and it's making me paranoid. Not a lot but maybe 10 specs in a 6oz cup. I don't know how this happened because I run a camco filter on a new hose. Will a simple drain and refill be enough to fix this? My last fillup was at a cabellas dump station out of what I though was a pottable spigot (not the flexable one right next to dump hole but the one maybe 10 feet before it). The water taste okay and smells okay, but just has little specs of dirt or scale in it.
  • This is pretty much why I NEVER use the tank water for drinking or cooking.
    But if I DID, the filter would be on the output of the pump......and maybe on the input too if the source is suspect.
    X2, I never drink from holding tank either even though I use the bleach mix after it has set a bit. I always carry bottle water or gallons jugs of water which I fill at home for drinking or cooking, and plenty of beer too for any extra drinking I care to do...lol!
  • Are you sure the sediment isn't coming from the hot water tank? When was the last time you flushed the HW tank?
  • The easiest way to avoid it is a good filter. We use three, one when filling the tank, one on the ice maker line and one at the output side of the shurflow pump. They are around $10. each, cheap enough.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
