Kennyg
Aug 15, 2015Explorer
SOOO Confused
Have yet to decide whether to go with the Brake Buddy "Patroit" system or the "Ready Brake" system! The local RV center swears by the patroit system and says the readybrake will create problemd with t...
klutchdust wrote:afrescop wrote:Kennyg wrote:
Have yet to decide whether to go with the Brake Buddy "Patroit" system or the "Ready Brake" system! The local RV center swears by the patroit system and says the readybrake will create problemd with the toad brake sytem because of the constant braking and its response you do while on the road.
I drive a 2006 Liberty Jeep and one of the drawbacks I saw with Patroit was the need to plug into Jeeps 12v sytem via cigarette lighter and reset the Patroit everytime you turned key off on RV; I.E. stop for gas and before starting on down the road you would need to go thru start procedure on the Patroit. They also say the ready brake would eventually brekdown due to and salt clogging up the cable sysem. Plus, the RV center wants over $3200 to install the patroit system.
Need some input; Advise as to your experience with either or both of these two systems. Last, which would be the easiest to install on my own and if its the Patroit system how would I avoid the 12v draw on the jeep??
Thanks in advance for all your comments.
I could see $3,200 if it were to include the Blue Ox base plate, tow bar and Patriot with installation.
When we stop for gas or anything else, if I do not turn the ignition key "Off" then there is no need to reset the Patriot. Even if it is off the setup procedure takes all of two minutes.
I bought the Patriot because Winnebago warns against using a surge type toad brake in the owner's manual. Ready Brake is a surge system.
Exactly what is Winnebago's concern with a surge brake system
