Kennyg's avatar
Kennyg
SOOO Confused
Have yet to decide whether to go with the Brake Buddy "Patroit" system or the "Ready Brake" system! The local RV center swears by the patroit system and says the readybrake will create problemd with the toad brake sytem because of the constant braking and its response you do while on the road.
I drive a 2006 Liberty Jeep and one of the drawbacks I saw with Patroit was the need to plug into Jeeps 12v sytem via cigarette lighter and reset the Patroit everytime you turned key off on RV; I.E. stop for gas and before starting on down the road you would need to go thru start procedure on the Patroit. They also say the ready brake would eventually brekdown due to and salt clogging up the cable sysem. Plus, the RV center wants over $3200 to install the patroit system.
Need some input; Advise as to your experience with either or both of these two systems. Last, which would be the easiest to install on my own and if its the Patroit system how would I avoid the 12v draw on the jeep??
Thanks in advance for all your comments.
  • We have the BlueOx Patriot system and are happy with it. (Different than a Brake Buddy).
    Instead of plugging it in to the cigarette lighter, we a jump box for power in the tow'd vehicle.
    Have not tried the other system you mention.
    (EDIT: Not an Advert and that's not the jump box we use. That was just the first image that popped up on Google)
Looking for advice before your next adventure? Look no further.25,181 PostsLatest Activity: Jan 22, 2026
