- CA_TravelerExplorer IIIThis is a spare tire solution by another RVer, no rim just the tire so that's it's available if needed.
- wolfe10ExplorerWe carried an unmounted spare on the roof of our 1993 Foretravel 36' DP when in Mexico where that size was not available.
Covered with Sunbrella material Dianne made into a custom cover.
Securely tied down to the Foretravel OE roof rack.
Never a problem. - donn0128Explorer II
Freightguy wrote:
I am looking for pros and cons.
Thanks,
Well excuse me! I guess I misread your post. - fj12ryderExplorer IIIWell, I am surprised that it is more common than I had ever thought. It still seems like a bad idea though. IMO anyway.
- ScottGNomad
I agree and just because someone has done it doesn't make it a good idea. Those who tie one down to the aluminum "railing" on the roof should check out how that is attached to the roof; by a few little wood screws into some plywood or sheet metal. - allen8106ExplorerFor what it's worth, I sure wouldn't do but to each his own.
- IvylogExplorer IIII love answers from those that have trailers with roofs that will barely hold a person and have 1/2" plywood roofs... usually without a ladder as they do not want you on the roof. My spare tire has stayed put for 75K miles...my DP does not bounce around like your trailer.
- wnjjExplorer II
donn0128 wrote:
Freightguy wrote:
If you are doing this I would like to know your setup also pros and cons
Thanks,
Fixed it for you. - NomadacExplorerMy tire weighs 100+ lbs. and I would not try to get it on my roof or get it down. It was heavy enough when I carried it in one of my storage bays.If I decided to take a tire with me I would put it in one of my storage bays where is covered and out of the sun.
- IvylogExplorer IIIThe tire in my picture above is wrapped in aluminum foil and plastic wrap. My newer used tire is wrapped in white duct tape which seems to hold up better than the plastic wrap. Getting it off is easy enough as you can roll it off and it will hardly bounce since it does not have air in it.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
