Blazing_Zippers's avatar
Blazing_Zippers
Explorer II
Feb 18, 2016
Squealing at hot water tank
When we turn on the water at the faucets/shower, etc. there is a squealing sound from the Suburban hot water tank.
I removed what I thought might be a check valve and cleaned it, but noise still continues. There is a second connection to the heater but I can't get that one to break loose. I just about pulled the tank loose from the mounting.
The local RV store guy just looked at me in wonderment when I explained the noise. I would have bought a part, but they weren't much help.
Help???
  • Squealing noise when running water?
    Does squeal happen cold & hot OR just hot?
    Cold & hot.......if on city water then check valve in city water connection
    Hot only.........then check valve on WH. Check valve can be on hot out or cold inlet
    Help???
    How loud is the squealing? And are you sure it's coming from the hot water heater? Is it only when the waters running or when the heater is running? Are you connected to city water or running the pump?
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
