Hammerboy's avatar
Hammerboy
Stabilizing a Fifth wheel
Hello Everyone,
We purchased our 34' fifth wheel this spring and am trying to figure out how to eliminate or reduce the amount of jiggling inside our unit.
Right now I have the Winfield stabilizers on the front landing gear, factory power stabilizers in the far rear, and use a BAL wheel chock in between the wheels. I cant really notice it when I'm walking around but when I am sitting and my wife is walking it is quite noticeable.
My thought is it's a long way between the front landing gear and the rear stabilizers (which are more for side to side motion vs. carrying weight)
So I'm wondering if I install a pair of scissor jacks behind the wheels like where a self leveling might have them that might help take out the bounce or jiggle
Thanks
Dan
  • I installed JT Strongarm stabilizers on ours. Has 2 struts mounted to each front jack as well as to one to each rear stabilizer. Takes out almost all the movement.
  • Ours is 36 ft long and we have the hydraulic jacks on front and scissor jacks on back and we have JT Strongarms on both front and back. It's not completely move-free, but it's much, much better than before the JTs.
    Remove the springs and wheels from the rig. Put it on cinder blocks and you won't have the problem any more.
    Just kidding.
    Much of the movement in a rig is because the rig is designed to move on the springs and tires while it travels down the road. The only way to eliminate that is to get the weight off the springs and tires.
    If you look at Class A, Class C and high end trailer leveling systems - they all take a lot of weight off the suspension. The most rock solid rigs I've ever seen were Class A with airbag suspension, airbags empty and levelers taking almost all the weight off the tires.
    Your rig moves in three directions when traveling or when parked. Side to side, up and down and front to back. Your suspension allows that movement.
    Steady fast helps greatly to reduce the movement, along with the other items you already have.
    The best thing we've done with our 36 foot TT is add a couple scissor jacks to lift the frame right behind the rear axle, and I use a solid pyramid screw jack under the front corners to hold most of that weight.
    We also deploy the Lippert stabilizers and use the X-Chocks.
    Another big reducer is to put plastic leveler blocks under the folded out stairs. The weight of a person stepping on that bottom step puts a lot of twisting pressure on the suspension. Having that weight supported by the plastic blocks stops that movement.
Looking for advice before your next adventure? Look no further.25,152 PostsLatest Activity: Aug 01, 2025
