You would be better off the read facts than identify yourself as a devotee of those anti government persons using the term Sheeple. Do you use Highways and Government Parks?
A Clean Water Crisis
The water you drink today has likely been around in one form or another since dinosaurs roamed the Earth, hundreds of millions of years ago.
While the amount of freshwater on the planet has remained fairly constant over time—continually recycled through the atmosphere and back into our cups—the population has exploded. This means that every year competition for a clean, copious supply of water for drinking, cooking, bathing, and sustaining life intensifies.
Water scarcity is an abstract concept to many and a stark reality for others. It is the result of myriad environmental, political, economic, and social forces.
Freshwater makes up a very small fraction of all water on the planet. While nearly 70 percent of the world is covered by water, only 2.5 percent of it is fresh. The rest is saline and ocean-based. Even then, just 1 percent of our freshwater is easily accessible, with much of it trapped in glaciers and snowfields. In essence, only 0.007 percent of the planet's water is available to fuel and feed its 6.8 billion people.
http://environment.nationalgeographic.com/environment/freshwater/freshwater-crisis/
Cummins12V98 wrote:
If we are so smart why are we not making fresh water from salt water?
I never said "FRESH WATER" when referring to that amount of water on earth.
Same thing happened in the 80's in the Pacific North West they declared a water shortage and had people water lawns and wash cars only on even days if their house number ended in a even number and same with odd numbers.  It was a feel good thing that in reality became a way to increase the water rates.  The reason is because people started using a lot less water trying to do the "RIGHT  THING" .  Then the utilities said they needed to increase rates to cover expenses because less water used meant less revenue and the "SHEEPLE" went along with it!  Guess what, the emergency was declared to be over and the rates remained the same.
If there is not an emergency to deal with the politicians have nothing to run on.
