D_E_Bishop's avatar
D_E_Bishop
Steampunk Workshop Macerator Pump
I learned about this hack to build a macerator pump using a garbage disposal and decided since I no longer had my Sewer Solution, I'd try my hand at this. With a couple of exceptions I had to buy the supplies needed so it cost me a little more than $50, more like $105.00. Still not a bad price considering a SS is about $110 with 20' of discharge hose and a macerator pump will run $200 to $350.
I lucked out and there was an ad for a Badger 5 on Craigslist for $40, I offered the owner $30 and she said okay. Got it home and found that the electrical had never been hooked up. The tinned tips were bright and shiny and straight as a pin.
A few changes I made in mine, no copper scrap laying around so I used 1/4" aluminum and added a rubber gasket to ensure a good seal on the discharge side. I didn't have a 3/4" NPT tap on hand so I bought a drill and tap kit on line. I did not like the thought of the threads on the bolts Jake used cutting into the plastic ears on the 3" hose connector. I used SS but with a hex head. 1 1/2" was the first one with a smooth area for the ears to sit on. Cut about 3/4" off the threads.
On 04/08/ we're taking off for a couple weeks, I normally try and dump before leaving on the last day but this time I'm going to refrain from dumping so I can see if the whole thing will work for me. I do have a backup in that if it doesn't work, I can dump at the storage yard.
  • I have been using my modification of a garbage disposal for my tanks for years. Hope yours works as good as mine. At times I pump 75 feet thru a 3/4 inch hose.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I still like my Flo-Jet. runs on 12 volts. I always have 12 volts Don;t always have 120 VAC.
    As for the Sewer Solution.. I do not like that, uses Fresh water which we are running out of to do a job better done by a few watts of 12 volts
  • Good idea for the money involved, but those things are big, heavy, and don't run off 12v.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
