rockhillmanor
Jul 11, 2016Explorer III
I had the SAME problem with my Tracker. And I even had everything installed by a know all RV shop and when I pulled out with my toad the steering wheel locked. :R
I found on mine there are '2' key positions for accessory. One will lock the steering wheel when towed and one will not.
To this day whenever I hook up the toad I turn the wheel to double check I have the key in the right position BEFORE I tow it.
Sit in your car and turn the radio on and then turn the key to accessory to see where it will leave the radio on and you will most likely find you have 2 accessory key positions also.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
