timotb's avatar
timotb
Disable Steering wheel lock 05 Liberty
I have a 2005 Liberty 4x4 that will be towed behind an RV coach. Today we discovered, during a test, while being towed behind the RV and with the ignition off, a sharp turn will engage the steering wheel lock causing the front wheels to bind and not return to neutral.
How can the steering wheel lock be disabled? Turning the ignition to ON will bypass the lock and will run the battery down. Installing a battery disconnect so the key can remain in the ON position bypasses the tow brake assist. With the key in the accessory position, the steering wheel lock will still engage in a turn.
Suggestions?
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
