IR's avatar
IR
Advance Trac Light On / ABS and Crusie Disabled
Has anyone fixed their 2021 Ford E 350 Super Duty? I own a Thor Daybreak 22 GOF. It never fails when driving with cross winds; light comes on. Any fix for this issue ?
  • This is a known issue. You have to reprogram the ABS module with the latest software. You can check for the code with a scan tool to make sure.
  • Your best bet is to turn off Advancetrac prior to driving in a crosswind.  In some models this is done by pressing the traction control button for about 5 seconds +/- (I have no idea if this will work in your particular vehicle. If the warning has already come on, you have to stop, turn off the vehicle, restart it; then disable Advancetrac.
    Upon pondering this further, if you are driving in a heavy enough crosswind that you are making steering corrections that are large enough to trigger the ABS/cruise control shutdowns, I wonder if it is wise to be using cruise control in those conditions to begin with.
    • IR's avatar
      IR
      Hello,  Thanks for the reply. Did not think about turning it off.  Good point. But loosing ABS braking in an emergency represents a safety risk in any situation.   Ford needs to get a fix for this issue permanently. I will definetly try this on HWY 287 and I-40 near Amarillo.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
