Your best bet is to turn off Advancetrac prior to driving in a crosswind. In some models this is done by pressing the traction control button for about 5 seconds +/- (I have no idea if this will work in your particular vehicle. If the warning has already come on, you have to stop, turn off the vehicle, restart it; then disable Advancetrac.
Upon pondering this further, if you are driving in a heavy enough crosswind that you are making steering corrections that are large enough to trigger the ABS/cruise control shutdowns, I wonder if it is wise to be using cruise control in those conditions to begin with.
- IRJun 14, 2026Explorer
Hello, Thanks for the reply. Did not think about turning it off. Good point. But loosing ABS braking in an emergency represents a safety risk in any situation. Ford needs to get a fix for this issue permanently. I will definetly try this on HWY 287 and I-40 near Amarillo.
