SoCalDesertRid1
Jul 14, 2016Explorer II
rockhillmanor wrote:On the Ranger, I disconnect rear driveshaft from axle and tie up to frame with bailing wire, disconnect battery via quick disconnect terminal clamp, put key in run/ign position.SoCalDesertRider wrote:You have so many vehicles in your sig can't figure out what you tow! :B
When I tow my small vehicles on the tow bar, I disconnect the battery, put the key in the RUN/IGN position, and put transmission in Neutral (or disconnect rear driveshaft on the Ranger).
I haven't had a steering wheel lock up on me using that procedure.
I've never tried towing with the key in the ACC position.
What are you towing with the key in the ignition position? If you disconnect the battery how do the lights and brake assist work?
On the Samurai, I put transfer case and transmission in nuetral, front hubs unlocked, disconnect battery by quick disconnect switch next to battery, put key in run/ign position.
I use a set of magnetic towing lights, connected to the truck's trailer light wiring plug, which are not part of the towed vehicles' wiring systems.
I don't use a towed vehicle braking system. The Samurai weighs under 2500 lbs. The Ranger weighs under 3500 lbs.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
