- D_E_BishopExplorerI have two suggestions, first try the manufacturer and second try this; LINK
I forgot, usually there is a yard near a manufacturer that buys end of run and left over surplus. Try searching for yards near the plant. Also the parts dept might know. - myredracerExplorer IIchallengerdoor.com makes RV compartment doors and every door is built to order. They sell to the public too.
- fj12ryderExplorer III
- Jay_PatExplorer
SidecarFlip wrote:
As an FYI, I had a Lippert OS storage door that leaked rain water. Had to take a brass hammer and bend out the inner aluminum lip so it contacted the bulb gasket on the door more tightly. Bad fit up from the factory.
I have two and so far they have never leaked. I like your solution if it ever does.
Pat - SidecarFlipExplorer IIIAs an FYI, I had a Lippert OS storage door that leaked rain water. Had to take a brass hammer and bend out the inner aluminum lip so it contacted the bulb gasket on the door more tightly. Bad fit up from the factory.
- IAMICHABODExplorer IIIThat makes it easier,just go to EBay and punch in that info and there may well be an exact match.
- Jay_PatExplorerJust check mine and I have a sticker. Says Lippert Components and has the size description.
Pat - machuntExplorerJay pat nope never thought of that
- Jay_PatExplorerDid you check the inside of the door for an id sticker?
Pat - machuntExplorer2011 outback 5th wheel, outside storage door
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 21, 2026
