rbp111's avatar
rbp111
storing propane canister under fifth-wheel
I store 2 1 lb propane tanks under the front of my fifth-wheel trailer. There are also 2 batteries under the same place, although the batteries are covered and vented to the outside. I have looked all over to place the tanks somewhere else, but where?
I fear the batteries will give out a spark and/or the propane tanks will leak. Thus giving them to explode, right under where we sleep. Any suggestions, or am I worried about some thing that won't happen.
  • My propane, batteries, solar controller, transfer switch, inverter are all in the front compartment together.
    But then mine is not sealed very well either. I figure that door will just blast open if there is an issue.
    You are worried about something that won't happen.
    If you want to feel better about it, have a small fan added to move more air through the compartment. You could also put a divider in the compartment, or get an airtight box for the propane cylinders.
    I've never heard of a battery sparking while in normal use. The sparks happen when being connected/disconnected or jumped.
    Also do a leak-check on your propane cylinders if you are concerned they are in bad condition.
  • Is it in a confined space? I have my propane and batteries in the front compartment but the batteries are vent and so is the compartment You may be over thinking this.
Looking for advice before your next adventure? Look no further.25,167 PostsLatest Activity: Oct 05, 2025
