Jbrowland
Dec 19, 2017Explorer
theoldwizard1 wrote:
First get a jiggle siphon (requires the gas can to be above the generator tank) or buy a small battery operated fuel transfer pump. Thank me later.
Most attached garages are required to have fire "rated" walls. If a fire starts in the garage there will be a lot of time to evacuate using other doors.
Also, most garages are well ventilated. Adding more ventilation, perhaps even a solar powered fan, is a good idea.
After that, I would not worry.
EDIT : I missed the suggestion on the OSHA rated fire cabinets ! EXCELLENT SUGGESTION !!
I have been looking at both the OSHA cabinets and that jiggle siphon. Both look great.
Some of your other suggestions don’t apply to me (but thank you fr them) as a I live in a 3 story townhouse. The garage is directly below the living quarters and other than the door to the garage, there is only one other door to get out and it’s 6 inches away from the garage entrance. I have three shared walls with neighbors and have zero outside space in addition to a cranky HOA. Add to that the gas can and genset Storage space is about three feet away from a water heater with an open flame. My case is not typical and far from ideal for gas storage regardless of statistics being in my favor for many reasons. That’s why I am having a hard time with this and why it may appear that I have no knowledge of common sense. Add to that, I’ve never even owned a gas can before so this is (WAS at this point thanks to so many excellent comments) new to me. See my other posts for specifics and thanks for your thoughts.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 24, 2026
