LITEPHIL
Nov 25, 2020Explorer
I had mine on two separate trailers. Really works well. Simple set up really. Drill and mount as they say and then just drive perfectly straight on flat ground and stop and loosen the two big jam nuts and tap the cams so they're center in the bars and then tighten them up. After many miles you will flip the cams over due to wear on the cams. People over react on the set up. Really prett easy.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
