DustyR
Nov 26, 2020Explorer
LITEPHIL wrote:
I had mine on two separate trailers. Really works well. Simple set up really. Drill and mount as they say and then just drive perfectly straight on flat ground and stop and loosen the two big jam nuts and tap the cams so they're center in the bars and then tighten them up. After many miles you will flip the cams over due to wear on the cams. People over react on the set up. Really prett easy.
X-2
I have used this setup on every trailer I've had since the seventies. E-Trailer has a very good set up article and if you follow all of the steps you will end up with a very stable combination. I experience minimal sway from traffic and the only truck that will disturb this combo is a 20' freight truck.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
