Racerx11's avatar
Racerx11
Stripped bolt on Reese WDH
I have a Reese dual cam WDH, and the bolts that hold the cam part thread into the frame.
Found THIS today and the rest are very loose.
Question for those more mechanically minded, I am just going to drill this through the frame and get the appropriate length grade-8 bolts, nuts, washers and probably use a .125" plate on the other side that everything bolts through.
Anyone see a problem with that if it's not torqued very much? I will actually use either crush washers or maybe castle nuts if I can find some, nylocs would even be better.
Also, I may just take it in and have it welded on, anyone think that would be a problem seeing how the frame has ton of stress going through it?
Thanks!
