StarkNaked's avatar
StarkNaked
Explorer II
Nov 05, 2022
Strong winds and water heater problems?
Could strong winds cause a overheating problem with the propane water heater?
Winds blowing at 20 to 30 mph directly into heater vent this morning. Water got hot enough to vent out pressure valve. Figured out it was venting because I could hear pump cycling on and off.
Shut heater off. Turned back on. Switch lamp showed over temp lockout.
Water temp over 150 degrees a half hour later, and even after running some cold water through with heat off.
Suggestions?
I'll check heater burner tube and clean when I get home.
  • enblethen wrote:
    Check the burner tube for debris. Check the orifice for debris. Clean with alcohol.
    Thanks!
    After the wind and rain calmed down, and after the tank was flushed of hot water, and completely cooled down, I tried turning it on again.
    So far, so good. Heated up with no error code or over pressure venting. Hopefully just too much wind pressure blowing into the flue. Plus wet inside from rain blowing in.
    I'll do the burner tube cleaning when I get home.
    I'll update after tonight and shower in the morning.
  • Check the burner tube for debris. Check the orifice for debris. Clean with alcohol.
  • enblethen wrote:
    My guess would be no water in tank!
    Make sure winter by-pass is not set to by-pass
    Plenty of water in fresh tank. We have been doing dishes and showering for three days. Water heater has been working fine till this morning.
    Timing started right after our next door neighbor left. He had been our wind block and was protecting us from the strongest gusts.
  • My guess would be no water in tank!
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
