atleif's avatar
atleif
Suburban 3burner/stove combo
Not sure if this should've gone in the food/cooking recipe area or somewhere else so I can move it if needed. I recently bought a travel trailer a few weeks ago with a Suburban 3 burner (with twist burner spark)/ oven combo and have had nothing but trouble with it. The front burner sets off an alarm everytime...even just with a tea kettle on top. I am guessing this is because the overhead range doesn't extend far enough. The back left one will occassionally set it off as well. It takes for friggin ever to cook stuff on the burners. I wonder if the grate is too high. Even trying to cook a single egg in one of those mini 1 egg sized cast irons takes easily 7-10minutes. I have never seen a slower burner in my life. It takes 10-15 minutes to get a cup of water to boil. Finally I have only used to oven once so far but it smoked big time. From what I can tell you basically never want to put it over 350 (when I dialed it down from 400 I could instantly tell the difference) and even though I was able to cook my pizza it was great other than 2 (out of 6 the way I cut it)pieces were black on bottom but perfect on top. I am guessing these 2 bottom burnt peices are what smoked out my camper so bad. Does anyone have experience with this stove? I suppose I should know to rotate the pizza every 5 minutes or something like that...any input would help. So far I am of the opinion that this burner/oven combo is fairly worthless. Thanks in advance.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
