Terryallan
Aug 24, 2021Explorer II
Grit dog wrote:Max's Mom wrote:
I want: EASY hook up and unhook, to be able to back up and hook and unhook at ANY angle, QUIET operation while under tow, lightest weight and simplest maintenance… all while providing excellent sway control and weight distribution! Is this too much to ask???
Congrats on the new TT AND the new truck! You'll love the truck and sounds like an awesome combo!
The item that checks the most boxes here, for a very reasonable size/weight trailer for your truck, is a set of airbags. Seriously.
And a nifty little compressor like a Viair, or a bicycle pump if you're industrious.
Only thing it doesn't control is sway, but I've used exactly 0 WDH's in 30 years of towing likely 100s of different trailers. Including many miles and many trailers behind many half tons that were not near as well equipped as your truck. Only time sway is or has been an issue is either not near enough tongue weight, or trailer so heavy that truck is severely overloaded and physically couldn't control the normal little wiggles that a trailer gets due to various conditions and inputs.
The weight cops will have a field day with this, but deep down inside, they know I'm right! LOL
air bags also do not distrabute weight. So the lost steering control to the steer axle will not be returned. they will of course level the truck. But the front end will still be light. Only a WDH will return lost weight / steering control to the front. It's just physics. The rear axle will still be the fulcrum, and the trailer tongue will still be the load of the lever pushing down on the lever, and raising the steering axle. Much like a seesaw with one person on it.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
