Wishin
Aug 26, 2021Explorer
dodge guy wrote:
Go with the Reese Dual Cam. Once setup it is very easy to put the bars on and pull up on the cams. And it’s great at sway control.
I wouldn’t tow with anything else. The only thing better are the HA, PP.
This is what I've been using since 2008 on 2 different trailers. I will admit that it is more difficult to set-up initially, but once set-up I don't mess with it and it works great all season and from year to year. I've towed 30-40k miles with it and have no issues.
My 2nd choice would be the Equal-i-zer 4 pt hitch. It seems much simpler and most people seem very happy with it as well. The rare person that has used both seem to prefer the Reese Dual Cam, but not by much. I have researched the Equal-i-zer and the pads seem to help people with the noise, which is one of the main complaints. A negative would be that each head is sized for the bars so a new trailer might call for a complete replacement if you need to go up or down in size for a heavier or lighter tongue weight.
I've heard the Equal-i-zer is good for hooking up at any angle and I have found the same to be true with the Reese Dual Cam. When I park it at my house, my trailer is level on a side hill (tires on concrete pads of the same elevation) and my Suburban is aimed down the hill and at a tight angle so I can hardly get between the bumper and trailer frame. I have no issues hooking or unhooking.
These are the only 2 hitches that I would consider, other than ProPride or Hensley.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
