hawkeye-08
Mar 11, 2015Explorer III
to the OP,
Do you have a wire connected at stud near fuseblock under hood as needed? Does it have 12v? trace that wire to the 7 pin connector, does it have voltage? if it does, check trailer wiring (including ground), if not, check the wire between the stud under the hood and the 7 pin connector at the back of the truck.
If you don't have these skills, then you will need to find a friend that does or open your checkbook or ignore the problem.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
