Ron3rd
Jan 03, 2021Explorer III
Walaby wrote:
That's the downside of the Superglide. Pinbox specific capture plate.
Didn't realize they had a multi-fit and a universal though, so maybe you could buy a universal plate and it would work.
If you don't have one, who knows how it will turn since the hitch will slide AND it will rotate with king pin.
If your 5er has the same pin box as your son's then yes, you can use his capture plate. Easily removed. But before you try, make sure you have same pin box, or his model will also work for yours.
Mike
Thanks for the info.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 23, 2026
