DanLee's avatar
DanLee
Supplemental Braking Question
I'm getting ready to move from a Tundra with a 8,500 lb GVWR tag-along TT, to a 40 ft DP towing a Honda CRV. I read the supplemental braking Sticky until my head hurt. My question is pretty basic. A 31,000 lb Coach towing a 3,500 CRV represents roughly a 9/1 ratio of tow-er versus tow-ee. If I used the same 9/1 ratio, imagine my 5,500 lb Tundra tow-er pulling a trailer weighing roughly 600 lbs. I certainly wouldn't use supplemental braking pulling a 600 lb, therefore, why would I need one with my Coach pulling a CRV? Seems like I should have plenty of braking engineering margin towing the CRV without supplemental braking? Welcome thoughts.
  • webslave wrote:
    Did you have supplemental brakes in your travel trailer?
    This is not a good comparison at all. I also happen to own a TT. It weighs about 2.5 to 3 times as much as my toad does. And I tow it with an 8,000 truck that weighs about a third of my DP which is 30,000#+ and the DP has air brakes and a very nice retarder.
    Bill
  • Did you have supplemental brakes in your travel trailer? They all do for both added efficiency in stopping and in case of accidental break away from the towing vehicle. Why should I treat my towed any differently? You can justify whatever you want to; brakes or no brakes, up to you. You can interpret most laws any way you want to...until you wind up in court in which case you may find that the armchair legal minds on the internet may not have it exactly right. I, however, sleep much better knowing that my motor home's brakes aren't carrying any extra load, even if said load is within the maximum capacity. The brakes will last longer, run cooler and suffer less mechanical stress if the load is shared by the towed's brakes which are already there just waiting for a means of actuation. For what I spent on the motor home, the base plate, arms and light wiring, the brake actuator was a pittance. Should the unthinkable / impossible happen (you learn with age to never say never) and my towed breaks away, the safety cables will / should keep it attached, but, my supplemental braking unit will keep it out of my expensive diesel engine. The potential repair cost, even for the body work would pay for a supplemental braking unit many times over. As you can tell, I have a supplemental braking unit, an RVibrake 2, for the peace of mind and the 2 minutes it takes to put it on the floor and plug it in, it is priceless and for me a no brained purchase.
    As I said, to each their own and you will probably do just fine without one until you don't, but, at that time it will be too late. For me the cost was easier to swallow than the gamble...the same reason I carry insurance on everything; to date, knock on wood, I've never filed a claim, but, you never know what the next few minutes may bring.
  • Is your coach's GVWR 3500 lbs more than it's actual weight of 31,000 lbs?
    If it's GVWR is 34,500 lbs or more, your coach is fully capable of stopping itself and the 3500 lb CRV. Therefore, no brakes needed.
    If you don't have 3500 lbs spare GVWR left on your coach, then use brakes on the CRV.
  • There is no definitive answer. Many of the laws commonly referenced apply only to "trailers". What is the legal definition of a "trailer" in YOUR jurisdiction? Here in Montana it is contained in MCA 61-1-101.
    In many areas the definition clearly excludes towed motor vehicles(such as, a "trailer" does not have motive power, or is used to carry property but not people). (MCA 61-1-101 (82) (a))
    However, many states have a "Braking Performance Law", where your rig must be able to stop within a certain distance (usually 40 or 45 feet) from a certain speed (usually 20 MPH) on a level, clean, dry, hard surface. Here in Montana, that law is MCA 61-9-312 (4). FMVSS also has that standard.
    Many people cite ethical or moral issues, or the potential for civil lawsuits.
    Since braking equipment is usually not included in any "Reciprocity Agreements", it behooves anyone who is towing a motor vehicle behind a RV to know the laws in EVERY state you enter!
    I'm not sure that is practical!
  • Just about every state has brakes required for anything being towed over 3,000 pounds. Some states are lower. Doesn't matter whether you live in that state or not. Anyone that ignores the law puts other travelers at risk. Saying you have a strong towbar is not an excuse. That towbar is pretty worthless in an accident.
    http://drivinglaws.aaa.com/tag/trailer-brakes/
  • Being a politically incorrect type person, I question a lot of assumptions that everyone else just goes with.
    I have a heavy DP (with a retarder and air brakes) and tow a light Jeep Wrangler with it that does not have any additional braking. I've been to Alaska and back, in the steepest mountains Canada has, over the Continental Divide I don't know how many times, entered the Tetons from Idaho, had 14% grades in Utah and so forth. So far I haven't found anything that was at all unsafe for my set up.
    As for the toad coming unhooked - we'll, there's a strong towbar holding the Jeep and two very strong aftermarket safety cables. There are other things that are more likely to happen than this.
    Some people will site your domicile state laws dictating what you must do. I've looked mine up and found one place saying I must have brakes on what I'm towing if it weighs over 5,000# and another place saying anything over 10,000#. Either way I'm well within those limits.
    Bill
  • The 400 lb if it should come loose would stop when it hit a mail box post. What would your 3500 lb car do if it came loose?
Looking for advice before your next adventure? Look no further.25,130 PostsLatest Activity: May 01, 2025
