blt2ski
Jan 03, 2020Moderator
Shocks, drop axel, depending on the actual weight of the trailer, lower psi in tires
Springs can also be designed to be softer. Is go with 5-6 leafs vs 4 with the same overall thickness.
Not sure of tire size. Example, if you have 235-85-16 10 ply tires, go to a 245-75-16 tire. About 1/2" smaller rsdious,, but carry the same wieght per tire. If you're using a 15" rsdious tire, there might be a smaller diam one, or ene a 14" that will carry 2500 or so lbs per.
More than on way to skin said cat issue.
Marty
Marty
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 04, 2026
