JBarca
Jan 05, 2020Nomad II
Grodyman wrote:
I have a Passport 153ML, which although a lightweight, is a pretty tall windsail, and sits high on a 5000lb 6 lug axle with traditional leaf springs.
I am toying with the idea of converting it to a torsion axle to smooth the ride and maybe lower a bit. Worth the expense?
I can't seem to find a suspension enhancement product rated for 5000lbs and made for a single axle trailer, all the MorRyde/Equa Flex/etc. are mostly for tandems.
Gman
Hi
Trying to help. You stated you have a 5,000# 6 lug axle setup. Where did you see this listed? I agree 6 lug, you can see it on the wheel, but the 5,000# does not seem to fit, or Keystone changed your camper and not their brochure.
Is this your camper? The 2018 Passport 153 ML in this brochure?
https://www.keystonerv.com/media/9142021/passport_brochure_2018.pdf
They list the dry weight as 3,514# with a payload of 1,085#. That adds up for a 4,500# GVWR. What does the VIN sticker say your camper GVWR is rated for and do they list the suspension rating?
Knowing Keystone, it is odd they put 5,200# axle tube with 5,000# of springs on a camper with only 4,500 GVWR. Keystone many times will put the suspension less then the GVWR on certain models and let the truck take some tongue weight. To save money, they could of put a 4,200# axle tube with 4,200# springs and let the truck hold 300# and meet the 4,500# GVWR.
Aside from that, I agree with the others, adding shocks will help. I do not agree with airing down the trailer tires unless you know exactly what your wheel weights are and still have some level of excess tire capacity. Ideally 15% extra capacity over the heaviest wheel.
The torsion axle needs a reinforced trailer frame above and beyond in most cases, then the leaf spring mount. This is what some posters were talking about adding the 2 x 2" tube on the bottom of the frame. But that may not work if the main frame is just too thin for a torsion setup. TT frames are not anywhere in the heavy duty cagatory, and ultra lights are even less duty.
Lowering the camper, the tire bump clearance was brought up. Dexter axle recommends 3" of bump clearance from top of tire to inside of the fender well. While 2 1/2" will just get by in some cases, it would be odd for Keystone to add lots of extra bump clearance to allow you to lower the camper. You may not be able to do it. Check and see.
If your wanting to lower it 2 to 3" or even 4 1/2" for getting better towing mpg, odds are it will not affect your towing mileage to where you can find it. The air drag is still too great.
To your question, is it worth it to spend $$$$'s on a torsion axle to help ride and lower MPG, I would say no. Yes, add shocks, they will make a difference in trailer ride and help the entire trailer from frame excess flexing.
Hope this helps
John
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
