bama5er's avatar
bama5er
Suspension Issue?
I have a 2013 Sierra 38' fifth wheel. I have lost 3 tires due to complete tread separation in 4 years. I thought originally that I had a load rating (E) tire problem. However, after replacing all 5 tires with a F load rated tire I looked closer at the suspension. It seems I only have about an inch clearance from the top of the tire to the RV chassis. This seems very close. I have ALKO axles with Lippert Equi-Flex. My dealer says this is normal for my suspension. The issue is there is evidence (hole) where the tires have hit the bottom of the chassis. I would say this means that 1 inch is not enough clearance. If the tire running at 60-65 MPH hits a stationary object (RV chassis) that would cause the tread separation and a rough ride.
Question: Is there a standard minimum clearance for this?
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 20, 2026
