- down_homeExplorer IIThe Fords with V6 non turbo except the Explorer with four wheel drive v6 which can be towed. The Expedition with non turbo V6 and the Edge with V6 2 wheel drive or all wheel drive. This coming year ask your Ford Dealer, If he acts like he doesn't know he can factory rep and they have a towing guide or did.
We had a 2 wheel drive 10 Edge and now a 13 Edge all wheel drive. - Sam_SpadeExplorer
tizeye wrote:
RWD generally cannot -
What exactly makes you think that ??
Why would you not simply put the transmission on N, regardless of what kind it is (hybrids don't count) and away you go. - tizeyeExplorer
Sam Spade wrote:
jepalmer wrote:
1) Does anyone know what SUVs can be towed?
I'm pretty sure that they ALL can be towed with a dolly, two down.
And I am positive that they all can be towed on a trailer, four up.
I understand the small extra hassles of a dolly but that gives you maximum flexibility.
ALL SUV's cannot be dolly towed. Essentially, FWD can be dolly towed but AWD and RWD generally cannot - ignoring towing a RWD backwards which is not recommended. Additionally, foreign makes are really bad about even addressing it in their owners manual, leaving out "Recreational Towing" and forcing you to look at the general towing (i.e. tow truck) section. There they will show the wheel supported lift which simulates a dolly, but then put other restrictions like 35 mph and 50 mile max while noting full trailer/truckbed towing preferred with all 4 wheels up. - tizeyeExplorerWhile the Motorhome list is excellent, it is a starting point. The 2017 should be published in Feb, so for new have to rely on 2016. As noted earlier, weight and towing capacity of the RV (some Class B as low as 3000lb) is a critical issue. The Motorhome list includes vehicle 'published' weights which may help you rule out vehicles if over the weight (plus buffer) limit. When narrowed down, go online and review the owners manuals as Ford, GM, and FCA are good about having a "Recreational Towing" section. YOu may find discrepancies within models. While not an SUV, I know there is a discrepancy with the Chev Malibu, where Motorhome indicated that is, the owner's manual indicates only the base 1.5L engine is. Likewise with the Ford Edge SUV, only the 2 optional engines are 4 down towable, where the base 2.0L in the Edge or any other Ford/Lincoln vehicle using it is not 4 down towable - but dolly towable if FWD. If looking at dolly towable, most dollies have a 5000lb weight limit which even the FWD Jeep Grand Cherokee (diesel or hemi) would exceed and V6 'maxing out', where the 4WD version is flat towable if the RV can handle that weight.
- TheLuvShackExplorerBuick Enclave 2WD and AWD.
- imgoin4itExplorerIn addition to most of the above comments you will find that manny GM vehicles can be towed 4 doen if equipped right,
- Sam_SpadeExplorer
I understand the small extra hassles of a dolly but that gives you maximum flexibility. - j-dExplorer IISo far this sounds a lot like "I want a big boat." Bigger than what?
Mid- to full-sized... Three row seating? Trailer towing capability? Four-Wheel Drive?
And what's going to be towing this? What weight can it handle?
Where are you going? Towing a heavy vehicle can be an issue in the mountains when it isn't along I-95 and I-10.
To me, mid-size is something like a three row crossover like Flex and Acadia.
And full-size is a Yukon, Suburban etc. 6000-pounds or so. - Dutch_12078Explorer IIIWe 4-down tow a 2011 Toyota RAV4 Sport 4WD SUV and love the car. It does require an aftermarket Remco transmission lube pump though, and that adds another $1000 or so to your setup costs. This is the second RAV4 we've towed, with a current total of about 50,000 towing miles between the two cars and zero problems.
- rk911Explorer
jepalmer wrote:
I need to buy, and then tow, a mid- to full-sized SUV.
2) Any recommendations for a particular vehicle
Thanks
I should have cautioned you to know and understand the various weights and weight ratings of your motorhome before buying a dinghy.
in general, the maximum amount of weight you can safely tow will be the lesser of the following:
- the GCWR (gross combination weight rating) of the MH minus the actual weight of the MH as it is loaded for travel (includes fuel, fresh water, food, clothing, people, pets, supplies, etc.)
- the weight rating of your tow bar
- the weight rating of your hitch
this is why it's vital to know what your MH weighs...by individual axle weights...as it is loaded and configure for travel before choosing a toad. Your MH will not collapse if it is overloaded but you will experience handling issues as well as longer braking distances and accelerated wear on suspension, brakes, steering, etc.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
