- JiminDenverExplorer IIWe have thought of trading up and I believe I would stay around 5500 lbs dry, keeping the loaded weight below 7000 lb. That should keep the tongue weight below 900 lbs.
5500 lbs dry is a lot of trailer if you look at what is available now. Especially if like us you can get by with a 3 season rig. - colliehaulerExplorer IIIMy opinion of the 80% rule. I have towed heavy with a Dodge 150 pickup. Did it tow the weight? Yes, but it took it toll on the truck. Before 100K miles I had replaced the ring and pinion, transmission and several front end componates. The ride of the truck was harsh and the drive was not pleasant. While the 80% rule might not be writtren in stone I think it is a good guideline. This is nothing more then my opinion from experience.
- DiskDoctrExplorer
Ron Gratz wrote:
... can you please tell us how your "gravity, wind, levers, and all that good stuff" gives a better maximum trailer weight than the values determined by TV manufacturers.
First, yes, I am having a little fun with the discussion. I figured a little over the top humor could lighten the discussion. But I will do my best to respond to your comments, as the discussion does have merit. I suspect you are having some fun at my expense, too, and that's okay, too. ;)
I am not redefining or defining anything. There are ways to get things that need doing, done. Towing heavy is not as simple as 'turn the key' I expend a fair amount of extra effort to monitor many different items when in that situation.
80% is in most cases a no-brainer. Sure, it takes caution and proper equipment, but IMHO the average experienced driver of the TV can handle the situation with little more than WDH and sway control, combined with a healthy dose of care and caution.
Above that, one needs to make the effort to be properly prepared, both in their own skillset and experience, and equipment. It is the driver + equipment that makes the grade (pun intended). Use what you have and don't be afraid to stack the deck in your favor ;)DiskDoctr wrote:
In any case, I tow regularly with my 4Runner V8 Limited (rated @ 7k tow) at about 6000-6500 lbs with a full cargo area in SUV. A bit of lugging on the steep mountains, but never had a handling or braking issue.**
By my math --
80% of 7000# is 5600# and
6000-6500# is 86-93% of 7000#.
Does that mean it's really okay to tow at 93% of the rated towing capacity? How about 100%?
Ron
If you are asking if it is okay to tow at full-rated TC,I believe it is certainly possible. After all, your TV isn't going to explode at TC + 1lb :D
For legality purposes, it is my personal opinion that GCVW is the rule here. Mine is 12k. It is also my personal opinion that TCs are based upon equipment performance and wear and tear. Mfrs will honor warranties at those numbers and below. They are in essence 'guaranteeing' the capability up to that level. GCVW is more of the 'safety' part of the equation.
As I've stated, the above is my personal opinion and should not be imitated or relied upon by anyone for any reason. Always obey the law and all safety ratings and make your own choices. IOW, I am not responsible if anyone tries to follow or imitate the above and makes a mistake. <--Disclaimer, since we are talking about 'capabilities' and are not condoning any disregard of anything.
The poster between us put it well when he said mfrs do not use a common standard. IMHO, it is just like the horsepower ratings a few years back. Mfrs were free to use their own standard, and they did. Some have even been accused of cheating or fudging the numbers.
Personally, I think it is a shame when mfrs deliver a TV with say 12k published TC, then give a 1k cargo rating, knowing the two shall never meet :(
I also offroad my 4Runner. Yep, it takes a toll, too. More repairs, the occasional fender dent, etc. It's a choice. I tow heavy and know it will take its toll. But when the trans is shot in the next 100k or so, I'll put in a bulletproof rebuilt one (send mine away) for about $6k. It is about 170k now and trans was serviced and fine about 20k ago.
My 4Runner was paid for many years ago and even if I had to put $10k in it over the next 5 yrs, I'm still far ahead of buying new. Less than $2k/yr? Heck, that was 4 monthly payments :o The other 8 months of the year are 'free' :D
Hope this helps clear things up a bit ;) - cmackExplorerI think the 80% rule (if that's what we're calling it) is born out the fact that there is no standard for defining towing capacities among the different manufactures. There may be a standard for a given manufacture but that only helps when looking at a specific manufacturer. As towing bragging rights become more common I suspect tow-offs (magazine comparison tests) will become more common also. Until a uniform standard is created all we can do it share our experiences and make decisions based upon them.
- Ron_GratzExplorer
DiskDoctr wrote:
Are you telling us that your 80% comfort factor is based on physics?
'Little relevance...' Really? how does gravity, wind, levers, and all that good stuff work in 'your world'??? It still pulls Down, doesn't it? Or does 'Gravity 1.2' work in some other direction?---
If so, can you tell us how physics was used to determine the 80% comfort factor, and what is the 80% applied to -- GCWR, GCWR minus loaded TV GVW, "Maximum Trailer Weight", "Maximum Trailer Weight" minus TV payload, etc, etc.
Then, can you please tell us how your "gravity, wind, levers, and all that good stuff" gives a better maximum trailer weight than the values determined by TV manufacturers.
I'm just trying to understand what your 80% value is based on and what you apply it to. For example:DiskDoctr wrote:
By my math --
Ron - Ron_GratzExplorer
DiskDoctr wrote:
You need to read a bit more carefully. I didn't say ORF is the source -- I said:
Your fallacious premise is asserting that Open Roads is the source of this guidelineThe earliest (12/04/00) reference I can find in Open Roads Forum to a towing-related "80% anything" is ---
As for what your learned decades ago -- many ways of doing things decades ago have little, if any, relevance to how things should be done today.
Ron - DiskDoctrExplorer
As with many towing myths, this application of an "80% rule" was based on a fallacious premise.
Unfortunately, if an opinion gets repeated enough times, some people begin to believe it is a fact.
Your fallacious premise is asserting that Open Roads is the source of this guideline :R
I've been towing for quite a while and I was taught and understood this rule decades before your quoted 'invented by' date.
Oh yeah, wasn't that about the time Al Gore invented the Internet? Lol.
Next thing you'll say is there is no such thing as Global Warming...oh, wait... :S you got me ther . ;) - RinconVTRExplorer
jsparkscougar wrote:
Does anyone know of a lite weight travel trailer good for a couple that could be towed with an SUV?
Look at Jayco light weight options and the Gulfstream Visa line. - Ron_GratzExplorer
APT wrote:
The earliest
The "80%" rule, guideline, whatever people call it often covered RVing vs. other types of trailers that are far easier to tow. It also generally covered the payload limitation of half ton vehicles and smaller for family RVing. As Ron suggested, there is no such thing as an 80% anything. Learn what each limit is for any given TV with respect to RVing and you can operate up to and some people believe over certain ratings.
(12/04/00) reference I can find in Open Roads Forum to a towing-related "80% anything" is in this post:
"---Find out how much your vechicle can pull then do not exceed 80% of that tow limit.. The 80 / 20 rule.
It's interesting to note that this early 80% rule appears to be based on the 80-20 rule which has nothing to do with towing-related safety factors.
In order for any xx% rule to have any meaning, one should specify: xx% of WHAT, and why XX%?
We previously saw a reference to "80% of rated towing capacity", with no definition of "rated towing capacity".
Ford specifies values "Maximum Loaded Trailer Weight" and then says the weight of additional options, passengers, cargo and hitch must be deducted from this weight. So, which number does the 80% apply to.
GM/Chevrolet specifies values for "Maximum Trailer Weight" and also lists weights which must be deducted. Again -- 80% of what?
Toyota specifies values for "maximum gross trailer weight", but does not say anything about deducting any weight carried in/on the TV.
Seems to me that, if the objective is to impose an arbitrary "comfort factor" on how hard the TV is allowed to work, the factor should be applied to the TV's GCWR rather than to some "rated towing capacity" which has no universal definition and often is mis-interpreted.
And, other than some mistaken application of the 80-20 rule, why should the "comfort factor" be 80%? If 80% is good, would not 70% be even better?
OTOH, if the TV manufacturer is comfortable with 100% and is willing to provide warranty coverage for 100% usage, why should we be telling people they must limit towing load to 80% of some undefined value?
All too often it is implied that, if one keeps the trailer weight below 80% of the "rated towing capacity", the other weight-related considerations will take care of themselves. This is true in some cases -- but not in others.
Consider a TV with published towing capacity of 9500# and published payload of 1500#. Blindly applying an 80% rule could give "comfort" to a person towing a 7600# TT which might have a TW of 1000#. However, that "comfortable" towing combination might actually be going down the highway with TT GVW in excess of GVWR.
Application of an arbitrary "comfort factor" to an ill-defined capacity value does not ensure a safe and nicely-handling TV/TT combination.
As APT stated, we should be trying to help prospective purchasers understand the reasoning behind all manufacturer ratings -- and the need to comply with all of them.
Ron - DiskDoctrExplorerAhh, I see JiminDenver types faster than I do and provided some good info, too.
44,070 PostsLatest Activity: Sep 18, 2026
