thskilla0069 wrote:
...I wouldn't of assumed just 2 inches higher would cause it ....I just hope dropping trailer to level or lower with hitch and having at least one friction sway will help it.
If you haven't already read the sticky on
Trailer Hitch Setup Procedure you really should. 2" high on the ball can make a massive difference and create the exact situation you describe. With the WD system set up properly, the trailer frame (when loaded) should be parallel to the ground and the front axle of the truck riding at unloaded height. If you don't have one or both of those correct it can make things really crazy.
KJ
