lonphi49's avatar
lonphi49
Sway issues
I read through the forum and cannot find my exact issue, so I apologize if this question has come up elsewear. I recently got a 17' TT Forest River 17bhse, towing with a 2015 f150 with a class 3 hitch, WD hitch. During my first outing, had a lot of side to side movement of the truck even at lower speeds, and saw the trailer moving a bit. I then added x2 traction sway control bars due to the weight of the trailer and also measured the tongue weight to be about 600lbs, which according to what i read, should be good for that trailer. My question is, despite these modifications, I recently took a trip which was about 2 and a half hours. Going 55mph or under, there was no sway at all, I will mention that i did tighten up the sway bars quite a bit. When we got on a bigger highway, the moment i started getting into the 60mph range i felt my truck side to side again and saw some sway in my trailer, forcing me to back down to 55mph again, taking the sway away. I'm not sure if this is normal, or if i'm doing something wrong? Towing at faster speeds is incredibly uncomfortable and makes me very nervous. Any input would be very helpful. I will also add that i did also check all my tire pressures, which were confirmed to be at recommended PSI on each one.
