thskilla0069's avatar
thskilla0069
Sway and jerking issues
I am making a big 2900 mile move across the country here soon. I decided instead of paying another company to just move my stuff that I would buy a trailer and pull it with my 2012 Ram 1500 4x4 Crew cab. This truck allows me to have up to 8500 lbs for towing. I bought me an 8.5x20 enclosed trailer that has a foot taller height than normal (for sxs when I buy another). I towed it home on a regular ball hitch as it was unloaded and it towed fine even without brake controller. It weighs 3,000 lb empty and I am only allowed to load 4k in it since its just a 7k trailer. I installed brake controller and got a use weight distribution setup. I loaded the trailer and first trip to scales showed about 1800lbs tongue weight and 6600lbs on the axles. I noticed some pushing back and forth on this small trip to scales from the trailer. I since then have redistributed my weight towards the back. Yesterday I went to the scales and had 7100 on the back axles and 700lbs of tongue weight (granted this is with weight distribution hooked up so I am guess probably 1000lbs of actual tongue weight). The back and front axles of truck were under the 3900 lb limit and I know the axles on the trailer are 100 over but I feel with a new trailer doing just this one trip and greasing the hubs daily on the trip should be all right. I went for a little trip down the interstate just keeping it at 60-65 mph. I got a bad swaying motion the one time and it was pretty scary. The things I think that are causing the issue with the swaying is the hitch for the WD I bought used is base of ball about 24 inches high and trailer is only 19 inches at the bottom of the coupler. I measured trailer with it hooked up and the front is 2 inches taller than the back. Being this trailer also is very tall and pretty square at the front I would imagine the wind is pushing the top of this rig and reducing my tongue weight along with the hitch having it nose up 2 inches. Instantly when I got home I ordered a new WD setup with adjustable hitch to be able to lower the trailer and get it level or even maybe an inch lower in the front and it came with just one friction sway linkage and 1200 lb bars. Do you think the 2 inches, no sway prevention, and having a tall front squared trailer could be removing a lot of my tongue weight and causing this sway? I know when I actually leave I will probably add about 200 lbs of residual stuff in the furnished place we staying to the front to add a little more tongue weight not to mention sons bikes and stuff in the back of the truck.
  • Nose high = sway. Get the trailer level or slightly nose down, 12-15 percent of your weight on the tongue and your sway issue will go away.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 15, 2026
