TommyC83
Dec 28, 2015Explorer
rexlion wrote:
If you eliminate WD/Sway hitches and friction sway bars right from the start, I don't know what's left.
Just a thought... is hitch weight more with the rzr loaded than without? Enough so that perhaps the trailer is riding a bit nose-up when unloaded, but nose-down when loaded? If so, a bigger drop on the drawbar might help.
I do lower the ball a notch when trailering empty to maintain a pretty level setup (usually just a touch nose down) I'm sure the tongue weight is increased a good bit when fully loaded but even my unloaded numbers are plenty heavy as its nearly 20%. I think it's just the overall combination when unloaded just compounds the issues.
