Earl_E
Apr 03, 2015Explorer
Very often trailers are really like on the tongue when empty. I think it's built that way so when you load it up it won't be too heavy. This will cause that slight or severe swaying back and forth. I wouldn't worry about much of this until you load the trailer up ready to go and then check it again. You will be surprised how much weight you will add.
I recommend the Andersen if you need control. You will have no sway bar--read the info at the website--but controls sway and equalization in another way. You can jack knife it with it hooked up with no ill effects.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
