Rough31's avatar
Rough31
Sway Fatigue
I am wondering if there are parts of the tow vehicle/trailer that will suffer fatigue over a long haul trip resulting in increased trailer sway while you travel. And what can be done to reduce those problems.
My truck is a 2011 Silverado 1500 with the 5.3L engine and factory tow package. The vehicle is rated for 10,500lbs. My trailer is the Sunset Trail 31SS. The factory dry weight is 7000lbs so I am well within my vehicles tow capacity. My hitch is an Equalizer with 1000lb sway arms.
I recently completed a trip from Southern Ontario to Disney World and back again. On previous trips my set up has been very effective and I felt I had weight distribution and sway control very well balanced. I do not carry more then 5 gallons of fluids and am consistent from trip to trip with what weight I have on board and how it is carried.
In both directions, day one was completed without noticing any significant sway issues. Day two was generally still comfortable, some jet wash movement was noted but nothing significant. Day three, on both trips was white knuckle at times.
On the trip South, I did not unhitch at the overnight stops and I wondered if that may have resulted in some form of fatigue of the suspension or other parts. For the return trip I made sure i unhitched each night and still experienced the same challenges. I raised my L-brackets and that did seem to provide some relief but did not completely resolve the issues.
I tried to note when it was the worst. It seemed after any rest stop I would feel more sway for another 30-40 miles and would see a significant difference after refuelling which would be the only period of major weight change.
Any thoughts are appreciated.
Looking for advice before your next adventure? Look no further.25,181 PostsLatest Activity: Jan 22, 2026
