Crabbypatty
Jul 07, 2016Explorer
You do not indicate what kind of hitch set up you have. Hitch needs to have sway control. I use the reese dual cam wd hitch and have never had an issue, now with second tv. Though a 1500 Suburban is probably close to being maxed out. Check tongue weight, hitch setup. If that doesnt cure it then beef up the Suburban heavier shocks and tires.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
