jmacpolo's avatar
jmacpolo
Sway with Andersen hitch
I have a Jayco X213 and I am towing with a 2017 F-150 with a max tow package. The first time I towed I did not have a problem but then I changed the 8" adjustable rack or stinger with the 4" rack which changed the height of the ball slightly. When I towed the next time the trailer was swaying all over the place. I don't know where to start to stop the sway?
Thank you,
John
  • I would just start over from the beginning with hitch setup.
  • No I have had the trailer for several years. I just bought a new truck.
  • Yes, but did you just buy the trailer?
    On the way home from the dealer, it towed okay?
    Went home and put all your stuff in it, then it started swaying? Right?
  • HI thanks for the advice.
    I had to trade the stinger because the new truck is so much lower that the old stinger was scraping the ground. I will try to move more stuff forward.
  • Sounds like you just bought a new travel trailer.
    When you loaded your stuff in the travel trailer, did you put it all in the back? If so that is your problem. Needs more weight up front.
  • The trailer tongue must be level or very slightly angled down. You need 10-15% of the trailer weight on the tongue. (I've never seen 20% be recommended before.) Without those 2 criteria, a trailer will sway regardless of what sway control you are using.
  • Sounds like you unloaded the hitch weight just enough to cause this problem. Curious on why you changed the stringer? Most will agree that 15 to 20 percent is what you want for hitch weight. Why not try it with the longer stringer and see if it improves.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 04, 2026
