john_b1
Jun 04, 2013Explorer
3.0charlie wrote:
My setup is an '04 Expy pulling a 6200# TT using the Reese DC (did the same bolt-thru-frame as you; I don't like them Reese bolts/screws...). Very little rear sag (1/2" to 3/4"), front is back even with 800# bars, and a tongue weight of 820#.
From all the reading I did prior to installing the DC setup (did it before 1st trip this year), I think your issue lies in the bars (1200#) vs. tongue weight (~920#) vs. tongue weight ratio (12%-15%). I'd start by weighing your TT at the scales, with and without the WD engaged.
Once done, adjust the DC links per the instructions (mine is set up at 5) and head out for a road test.
I totally agree it is too heavily barred and things can't work as they should in all bound up!! I had the owner of the hensley Co tell me you would be amazed how much a lighter weight bar will do as in a positive way.He was using 750 when I would have been using 1000 lb bars. jmho jb
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
